Studer 169 help
yipshee
Member
Hi guys,
I'm wondering if anyone has any photos of the cable that run from the console to the external power supply?
Also does anyone know where I can find replacement knobs?
Dave
Hello Dave,
The 169 is connected to the external power supply with a 2 conductors cable ( for zéro and +V )
Nominal voltage of power supply is 14 V DC.
Connector on 169 is a " DIN 45323", and bananas plugs on the power supply.
This information is coming from the Studer 169 Operating/Service manual.
Guy
Dave,
It could be a 3.5mm jack, but I'm not 100% sure.
I also checked again the manual and it happens that there are bananas sockets AND a jack connector both paralleled on the power supply unit.
May be you can get more information from here:
ftp://ftp.studer.ch/Public/Products/Mixing_Analog/169-269/
Guy
hi
i have one module of this desk
i would like to make a rack with it
i download the Manuel with schematic but i don t really understand
on the PCB we have 3 connections
2 x 13 pin and 1x9 pin
where is my +/- 15V?
48v?
and my out ?
i m very sorry but i would not break my 169 :oops:
thanks
regards
ok
i m progressing....
i suppose:
+15v --) PP2 - 10
-15v --) PP2 - 3
0v --) PP2 - 6
+48V --) PP2 - 1
input mic+line on xlr ( it s easy)
but i don t see the output
normally it ll be after the polarity switch
so it will be balanced...
so for the output
xlr 1 --) everywhere on the masse
xlr 2 --) PP2 - 4
xlr 3 --) PP2 - 5
is that ok?
thanks
Hi ilikeit,
Why didn't you tell us the exact reference of your input module ?
It is labelled on the pcb as 1.169.xxx
Anyway, you are correct for the power supply pins
( OV is wired on 2 pins PP2-6 and PP2-7 )
The audio output of this input unit is unbalanced on pin PP1-12
If you don't want to go through the MUTE and SOLO FET's you can use PP1-1 as output.
Don't know if you need them, but AUX pre-fader send is on pin PP2-13, and post-fader on PP2-11 (you have to link PP1-11 and PP1-12 toghether )
If you want a balanced output you'll have to build an additionnal board (SSM2142 or equivalent is a good solution )
Hope this helps !
Guy
Merci guy :wink:
this afternoon i m coming back to my house
so i can give you the serial number of PCB
regards
the serial number of PCB is
1.169.200-13
i had one PSU
with +/-15v & 48v
i m trying at this moment
it s OK
i don t listen it but with my oscilloscope i can checked!!
i have just one oscillation
but i think the earth isn t with the good pin
maybe a lot a pics later....
:grin:
i m obliged to make a balanced transformer in output??
so
i m trying to make my studer
and i have a lot a problem
when i m trying with a dynamic mic (sm58)
i have a lot of noise in mic level
i haven t voltage on the XLR when i switch on the 48v
also
when i m plugging the mic in line level
i have a little level (normally) but the signal is clean
i m checked the pin configuration for the input mic and its ok
my output is al right because the line level is ok
have you got any idea??
thx
