Excellent input!
Of course, the turn-signal thing is easy once yo know how it's done....-I was thinking there was a box of relays with logic if/and/or/not feeding it... There I go, overthinking it yet again! :roll:
That settles it, I like the starter harness idea a lot! -Looks like you bolt in the fusebox and just string it out from there... looks a lot easier than when I wired up that Beetle... (which really was from scratch.. only thing that was original was the fusebox)
Of course there's always something else you think of later... like a horn for example... :oops:
I'll ask about LED turn/brake signals... he might have a religeous objection, but I've even considered putting them on my own car for the exact reasons that you mentioned! (I'd have to come up with a mod to stop the flash rate from skyrocketing, you know the "you've got a bulb out" indication...)
Yes, there will of course be an additional switch position to drive the radio etc... Interestingly, the recent VW stereos will run for an hour without the key in the ignition, then turn itself off in case you've wandered off and forgotten that you left the radio playing... a nice feature, but yes you're correct, it actually "arms" from the "aux" and not the "run" position of course.
The chap in question actually has an original Shelby Cobra at the moment, but will be getting rid of it, for something that he can "play about with" in terms of mods and hopping-up... It'll be interesting how much he wants to keep as original (probably most of the outside stuff, for appearances sake) and how much he'll allow from the 21st Century... LED taillights are an interesting proposition... he might even want a slight "slug" on the turn on/off, so it's not quite as sudden...
Great thoughts!!!
Keith
