Probably a useful replacement for some older hybrids. I guess this is out of that group at National that's gotten some publicity lately for focusing on analog audio, which I suppose is a positive development.
Note that the blurb bullets at the beginning associate with the use as a buffer in a closed-loop with a fancy opamp. And what the devil does "Pure fidelity. Pure performance" mean?
I do find some troubling things in the application part of the datasheet. One in particular is this penchant once again to thinking that the use of servos to eliminate conventional coupling capacitors means there are no capacitors in the signal path. Rubbish.
Another quibble: Figure 4 shows what is implied to be a superior topology with d.c. coupling at the input, including to the volume control. Using the opamp shown with its 10nA bias current is going to be a recipe for some scratchy nasties when the control is adjusted, and the ~1 sec servo tau won't keep up. Bad idea.
Another concern is the peaking shown in the graphs on page 5, and worse, the absence of a most important datum, the source impedance that was used to generate the curves. This should be fixed.
But still in all, probably a part worth playing with. Thanks for posting it.
