Hey all,
Was stumbling around the net recently looking for things to experiment with while waiting for parts to arrive, and came across this:
http://home3.netcarrier.com/~lxh2/marsh.html
Not the first time I've seen it mind you, but given the way I've started changing my distorted guitar recording techniques to direct-to-disk instead of miked-cab, it got me curious again. From a quick search of the forum I notice that a few members here like to use convolution plugins to simulate guitar cabs (also the way I currently do it now), but a little DIY-ed box that simulates the cab sounds far more appealing - the latency with convolution plugins shits me when live-monitoring, especially with some of the better/bigger cab impulses.
I already have a preamp that I love to bits (a two channel adaption of the Soldano X88R), so in the above schematic I'm thinking of building from opamp #8 onwards, omitting the preamp section and picking up the "LF boost" and "damping" controls along the way.
I should also point out that I just finished an untested layout of the Marshall SE100 cab sim (excluding the power soak section and LED signal indication), but seeing the LXH2 again I'm wondering if it is any better sounding than the SE100?
Any thoughts?
Cheers! :thumb:
Any thoughts?
Cheers! :thumb:
