One of the quotes referred to above:
[quote author="SSLtech"][quote author="buttachunk"] :guinness: is this the low-mid band ? (15nf) also, how would one "shelf it" ? :green: [/quote]
They don't shelf this one... The manufacturer instead uses a 4-gang reverse-log pot and makes a second filter which tracks alongside the first, in shelf mode. -if you want shelf, you simple switch over to that output... but making one requires 4-gang rev-log pots, and if people have a hard-time finding 2-gang versions for the 9k preamp, then this is only going to be tougher...
Keef[/quote]
So you need that one erased, too? -Please tell me why it should be erased.
Feel free to take as much space as you like to explain why it needs to be removed/edited. I don't see anything wrong with it.
I am not however going to take the time and effort to -as I posted in the other (now locked) thread- read, evaluate, filter, and edit/remove as required. -It's simply too much work.
If you say that it's not, then YOU do the reading/evaluating/filtering and request that the original posters edit/modify it. -I can't ask it any more clearly, and I DON'T think it's an unreasonable proposition.
I got wrapped up in some rather more pressing stuff yesterday (as it turns out, there are fourteen SSL consoles in this city alone which need a retrofit to the master fader section, and this stuff has to be organised in such a manner that it doesn't cause excessive disruption to studio bookings) so I couldn't watch the end of the thread, but it got out of hand, it was locked by another moderator, but I would certainly have done the same.
I predict the same fate for this one. -It seems like arguing 'ownership' of posted material is a dead horse that for some reason is still getting whipped.
-A particular quote about repeating an experiment and expecting different results has been attributed to just about everyone from Benjamin Franklin to Albert Einstein, so I can't know who said it originally.
I can tell you that this thread is getting locked. -So will the next one on the same subject, and the next.
It's not 'censorship', it's signal-to-noise. A few people seem to relish the confrontation, and if there's one thing to be learned, it's that you can't make any progress by fighting the same battle over and over with them, no matter who the opponent, no matter what the forum and no matter what the 'trigger' is.
Keith
