How close is the ACM 6802-T electronics to the famous Apex 460?
I believe the ACM 1200 will turn out to be another Apex 460.
6802 has been traced by Marik
here.
Not the same as the 460. Better for modding in my opinion as you don't need to scrap the second triode used in the 460.
Not familiar with the '460, but if it's indeed like that, would we like it ? (at least for the price)
You should like it. Keep the boards inside and drop the second half of the circuit so you have a standard plate-out (so you can now follow a G7, 1/2 a C24, M251, etc. with a few component swaps). Drop the heater to 6V by bypassing the diode on the heater regulator. Many mods and experiments have been documented here and elsewhere.
In my opinion, the biggest improvement you can make with these mics is to fit a good capsule.
