spica
Thanks a lot for the suggestions, guys. I will try swapping the capsule first and see how that effects the tone. I will report back.
Cheers.
Cheers.
Hi Greg. Which ribbon do you have? Thanks.okgb said:Anyone have the original price list ?
i bypassed the electronics in my 48v ribbon
[ cause they were noisy ] but i don't need another
ribbon so for sale it goes
mitsos said:Second, and this is the big problem... if I tap the mic on the headbasket or right below, the mic cuts out for a second, then comes back to life. I opened it and cleaned the boards with alcohol in case that was causing the problem. Any ideas what could be causing this?
mitsos said:First question... my output cap is a 10uF lytic instead of the 1uF on the 460 schemo (and what most people have claimed to have). Other components seem to follow the 460 schematic. I suppose I should change this to 1uF or so?
mitsos said:If I attached it right, the schematic is below.
Would be interesting to hear from people how they fit their acquired ACM-mics into their total mic-usage.
And last but not least, please keep your findings/mods/experiences posted.
IIRC the '1200 uses the second triode-section for a cathode-follower.
mitsos said:aCM1200 = Apex 460... search for that, there is tons of info.
If I attached it right, the schematic is below. I think I also changed C6 for a panasonic FC or something, but can't say if it made much difference. The mic is OK as is now, but I still need to change the zeners to lower the B+.
hope that helps!
