madriaanse
Well I got a bit of extra time on my hands and have been thinking about the best way to implement a line-in (using a 31267 I/P transformer) on my EZ1290's. I have a few things in mind, and would love to get your feedback.
A:
Add a 1X12 rotary and a mic/line switch next to the existing 3X12. The 1X12 handles switching of the line input's 7 gain positions, the 3x12 handles switching of the mic input, and the mic/line switch selects between the two. Pros: no gain positions lost. Cons: Added cost of a 1X12 Grayhill, mic/line switch, more holes to drill
B:
Lose the upper 3 gain positions of the 3X12 (65, 70, 75dB), and add 3 line input positions below the 20dB gain position. Out of the 7 line in positions of an original 1073 I would probably pick the lowest, middle and highest. Pros: simple, cheap, effective Cons: preamp max gain reduced from 75 to 60dB, coarse 15dB gain steps for line in.
C:
Both A and B are compromises. Ideally I would want to use a 3X24 PCB mount rotary, but I don't know of anyone who makes one. If there is such a beast it will be pricey I'm sure. Is there an Elma or Grayhill I need to know about?
If you have no clue what circuit I'm talking about, please see original here:
http://www.technicalaudio.com/neve/neve_pdf/1073-EH10023.pdf
EZ1290 here (Page 10):
http://www.musiciansgig.com/ez1290/assembly.pdf
Thanks for your input!!
M.
A:
B:
C:
M.
