Gates Sta Level 6V6 Screen Voltage
plassy
New member
Hi, this is my first post.
One of my Gates Sta Level has no R42 register and its 6V6 Screen Voltage is +245VDC. The other Sta has R42 and its 6V6 Screen Voltage is low +210VDC. Both original unit, no modification. STA LEVEL Schematic on the net has R42 and +248V on the Screen, so I'm confused...
Does anyone know what is the correct 6V6 Screen Voltage for STA LEVEL?
Sta Level Schematics:
http://www.waltzingbear.com/Schematics/Gates/Sta_Level.htm
It's not very important. This is an 8-Watt amplifier asked to deliver 0.25 Watts. Whether it is really 8W max or 7W max hardly matters.
Thank you very much for the answers. The plate voltage and B+ between the two units are the same. The sound is the same with or without R42. With R42, the screen voltage of both units is about +200V to 210V. Maybe the lower voltage is due to old C7 leakage.
Leakage possible answer.
Have you measured using the same pair of tubes in both amps? I can imagine tube variation and condition being a factor.
