How to attenuate signal in an effect loop (guitar)
steppenwolf
Augsburg, Germany
Hi Guys!
I have a problem I tried to solve but didn't come far, maybe you have an idea.
I`m using an effects precessor (50k input impedance) inside a tube buffered effects loop (max 10k output impedance) and when I switch to clean channel, I overdrive the unit due to the large dynamics of a clean sound. I would like to put a switched attenuator before the unit to get rid of some dB in that case.
I tried a pot, but it takes away high frequency when turned down.
Is there any other possibility to get rid of some level without loss?
I would like to do that with passive components...
Thank you very much!
Steaan
Use a lower-value pot?
have you tried putting a cap across two legs of the pot? This will retain some of the signal. Try something like a 150 picofarads. These are what fender uses as bright caps.
Here is some reference info on tube buffered effects loops..
http://www.diyguitaramp.com/fxloop.html
There is alot of info on effects loops at the forums at:
http://www.ax84.com/bbs/index.php
Just do a search for effects loops.
If you have a 12ax7 tube that both sides are used for the in/out buffer of the loop...you can try a 12at7 which will lower the output a bit.
Thanks for your help!
I'm just looking for something that is only switched in the signal path to take away some dB when playing clean stuff, using a different tube would affect all
channels...
PostPosted: Sat Jun 14, 2008 2:25 am Post subject:
Is it OK to go lower than 200k when the load impedance is already 50k. I don't want to load the tube to much...
What about active electronics...could I use another tube buffer or something like that?
