TornadoTed
Re: drip la2a pcb ver3 (atoms) build thread.
« Reply #60 on: May 08, 2009, 06:24:41 PM »
Well how does the ver3 atom SOUND and stack up to the previous versions?
Not a good sign seeing the thread just kind of drop out!
I have 2 Drip LA2A's a version 2 that I brought from someone on here and a version 3 I built myself. I am getting a little more distortion with the version 2 than the version 3 when pushed hard. The version 2 is great on bass and electric guitars but is a bit much for vocals which the version 3 excells at as well as acoustic instruments. They both appear to be calibrated the same and work the same. I do not know if this is a difference with the versions or if it's the tubes, components etc I haven't been able to find a 'fault' with the version 2. Whether it be intended or accidental I really like the fact that they are different!
Giant Wafer Studios
www.giantwafer.com
canidoit
« Reply #61 on: May 08, 2009, 09:14:34 PM »
Drip I just noticed on your manual the Opto 3 DC version. When will that be out? I would like to know if there are any sonic differences between the current Atom version and this DC version. Why have you made a DC version, is there any particular reason? Is it more technical or more sound reasons?
I would like an DIY La2a that sounds like the real La2a, is this possible? There's really not much reviews here or online of your Drips La2a from a sonic perspective like they have at audio forums and audio recording reviews for audio equipment. If I am mistaken, can someone give me links to posts or online reviews of the Drips models reviewed. Most posts that I have read have based their opinions on the La2a DIY clones without hearing a real La2a.
iva dunit formerly known as canidoit
canidoit
« Reply #62 on: May 09, 2009, 12:23:38 AM »
Also the T4B cell that UA uses comes in two sizes. I have read that the short and long versions are internally the same. The question I would like to know, did you design the Drips card with the long T4B cell in mind that will fit in the La2a Purusha case? I am thinking of maybe getting the long version, but I am unsure as to whether it will fit in the Purusha case, incase the Drips card was build around a shorter T4b cell. I had a look at your T4B cell but it does not state what height it is.
VoiceOverMike
« Reply #63 on: May 09, 2009, 03:29:31 AM »
<I do not know if this is a difference with the versions or if it's the tubes, components etc I haven't been able to find a 'fault' with the version 2.>
I've rolled a Few tubes in my ver3, and the change can be striking.
<Drip I just noticed on your manual the Opto 3 DC version. When will that be out? >
You should check the Drip Webpage and Board:
http://dripelectronics.com/
<I would like an DIY La2a that sounds like the real La2a, is this possible? >
Yes get the UTC iron.
canidoit
« Reply #64 on: May 09, 2009, 06:03:31 AM »
What tubes did you change and what brands to and what were the results? Do you have more of a description from a Sound perspective. Striking is a little vague?
How do you compare it to an Original or Re-issue La2a?
VoiceOverMike
« Reply #65 on: May 10, 2009, 03:01:33 PM »
For the 6AQ5A, any old tube would work here. I piked up a bunch of Triad's at the the Groove Tube fire sale
12Ax7A- I'm using RCA's gray plates. Black plates would be nice here too.
12BH7A- This is where I hear the most difference, I've rolled Amperex and RCA. RCA is a little dark, the Amperex is a little more open at the top end.
You can go nuts trying figure out what is the best tube, there is no such thing. Just get strong NOS tubes and you'll be happy- trust me.
You can always roll tubes in and out later.
wassx
« Reply #66 on: July 01, 2009, 04:45:37 PM »
 :) Just finished my Drip Opto V3  :)
Only problem was my "NOledge" about center tap transformers  :-\
Ok, one thing: I've a 50Hz hum so grounding needs some more work
To all people thinking about it -> go for it, it's nice
canidoit
« Reply #67 on: July 04, 2009, 08:30:04 AM »
Is this the correct power wiring for 240 volts mains power using a Hammond 369JX Power Transformer?
substitute
« Reply #68 on: July 04, 2009, 09:53:14 AM »
I just fired mine up yesterday, I'm not absolutely positive about how to wire the primaries for 240v... but seems like you have it all sorted out.
Get ready for awesome!
canidoit
« Reply #69 on: July 04, 2009, 10:33:48 AM »
LOL, thanks mate  ;D
ilfungo
« Reply #70 on: January 18, 2010, 08:11:20 AM »
hello
I'm almost finished drip opto 4
Where can I connect the lamp on the front panel to power?
canidoit
« Reply #71 on: January 18, 2010, 08:25:38 AM »
hello
Drips responds to it here:
http://dripelectronics.com/forum/viewtopic.php?f=5&t=347
Just confirm with him the voltage you are using for the lamp.
ilfungo
« Reply #72 on: January 18, 2010, 10:16:34 AM »
thanks! :)
ilfungo
« Reply #73 on: January 27, 2010, 04:21:15 PM »
I want to say thanks to dripelectronics ;D
I just finished my  LA2A( opto 4) and sounds so wonderful
I'm waiting to complete the second T4B
Thanks!!!!!!!!!! :-*
ilfungo
« Reply #74 on: February 15, 2010, 09:35:28 PM »
Ciao
small problems with the VU meter...
analyzing the level of compression with pro tools  I saw that the meter represents twice the real compression
There is a procedure to calibrate the meter?
Thanks...
jyrki3101
« Reply #75 on: November 03, 2010, 01:45:22 PM »
HI, I have a question about the meter backlight options... 'Cause I havent found a 6V fuse type lamp for the hairball meter, I'm going to use 2 yellow leds in series.
I know this is easy for experienced people in electronics, but, I'm not sure how to avoid the strobo-effect on the leds if I put only a resistor between the 6,3V pad(pcb) and leds?
Do I need diodes to rectify the 6V AC and what would be the simplest way to do it ?
A simple wiring diagram would help, PLEASE?
I would greatly appreciate your information !!!
jyrki3101
pH
« Reply #76 on: November 03, 2010, 01:51:16 PM »
Last post August 19, 2019, 10:16:26 AM
by Rob Flinn
Last post October 29, 2020, 05:08:01 PM
by Delta Sigma
Last post June 12, 2013, 07:05:12 PM
by desol
Last post December 13, 2020, 11:08:05 AM
by JW
