wiring triad hs-66 transformers.
Hangman
Active member
Olympia, Wa
ok... so I'm wiring up some spectrasonics, I bought som hs-66 transformers
but I"m not sure how to wire them
the primary says "connect - pins 3-47 = C.T." and then "TERM 1-6"
the secondary says "connect - 9-10 =C.T." and then "TERM 7-12"
do I connect the unbalanced primary to 1 and 6?
how do I then hook up the balanced out? do I use 9-10 as ground?
ignore the CT other than to make sure they are connected. wire to 1-6 and 7-12. use search for more answers.
