Kingston
Moby said:Yes, EDCORS are really poormans transformers "Shit" in the high frequency is caused by huge nonlinearities in the 60k region. Firstthing I did when I recieved them was measuring and I was really dissapointed, but they are OK for prototyping . Lundahl are really transparent and no way it's comparable to the EDCORS. If you want clean sound that's the way to go. If you ask me I will go with Jensen.This is the first unit where I can really hear the edcor XSM 600/10k step up transformer at work. I can't say I like it much. I was surprised how grainy it sounded and how it shits all over "s" frequencies. No good. I'll start looking for alternatives. Lundahl certainly has a few that fit my mid-side plan.
Regardind crossover distortion it's probably caused by EDCORStoo because they are not symetrical (try to measure the Inductance). In the puh-pull arrangement it's really important. Of course I read that you matched the tubes. Hope you did that with various grid voltages
BTW, do you have hum problem?
I would prefer jensen and cinemag to lundahl, but neither of those seem to have a compatible line 1:4 ratio step up available with dual, separate windings (or even center tap, but maybe I'm just blind). I need the dual windings for mid-side encoding. This can be hacked into the edcors as well, but now I'm thinking it's probably not a good idea due to the imbalances between the windings.
I measured the cross-over distortion further. I don't think I have matched the 6BC8's well enough. this time I indeed need to measure them with various grid voltages, but also taking into account the imbalance of the edcor windings. Lot of work, but I have a lot of 6BC8's to try at least. I can see (and hear) the cross-over distortion even if I completely take out the sidechain off the signal path. Nasty wobble near the A/B gain stage zero crossing, a rounded off discontinuity and sounds like crap.
I have no hum problem at all. I see the usual 50hz transformer bump at about -90dBu. No rectifier harmonics at all for one channel (general noise floor at about -105dBu). The other channel has negligible rectifier harmonics at about -100dBu. I have extensive (read: paranoid) shielding where ever it's possible for all wiring, and an unnecessarily thick (and heavy) steel cage for the PSU transformer (which does surprisingly little, I might remove it completely).
But really the lack of hum is probably due to the correctly over-specified and high quality PSU transformer. It doesn't get hot, and never reaches even close to core saturation.
