Neumann W492 equalizer DIY project (PCB docs added)
hey 3nity , see attached file in Jarlehal post(the one saying : Here's my finished unit.
Thanks to AudioX & Gustav)
----->New Prodigy forum , new functions!
Cheers!
I'm so sorry folks. I promised you my w492 front panel files, but I've lost my memory stick. Argh, lost a few other things aswell..
Again, sorry folks. From now on I'll backup and backup the backup.
JH
I got all wima films (have to check which ones) and panasonic lytics from TAW.
Despite warnings I have decided to publish the PCB manufacturing documents of the W492 equalizer. I hope that it helps those who want to make their own boards. Documents are allowed to use only for DIY purposes.
http://audioxxx.googlepages.com/W492_copper_top_mirror.pdf
http://audioxxx.googlepages.com/W492_copper_bottom_mirror.pdf
http://audioxxx.googlepages.com/W492_GERBER.zip
Ptown, if you do the kits with the Omegs, Laura at TAW has them. They are $18 a channel IIRC. Maybe you could cut a deal with her to take what she's got left over off her hands. Thanks for doing this by the way.
IIRC Laura also have all the wima caps needed in here!
If I have understood right quite many are making their W492 with Omeg pots because of the lower cost than Sfernice. The problem is however that the section spacing of Omeg is 7.5mm (Sfernice has 5mm). Potentiometer pins can be bended but it is not very elegant solution...
It is not a big job to make an "Omeg" version of the pcb with 7.5mm spacing. If you are interested, please let me know.
I would still love to see this done since I'll probably end up etching a couple more of these. Thanks!
W492 with Omeg potentiometers:
http://audioxxx.googlepages.com/W492_omeg_copper_top_mirror.pdf
http://audioxxx.googlepages.com/W492_omeg_copper_bottom_mirror.pdf
http://audioxxx.googlepages.com/W492_GERBER_OMEG.zip
