Michael Tibes
Re: Neumann W492 equalizer DIY project (PCB docs added)
« Reply #180 on: May 27, 2009, 06:52:09 AM »
I'd love to see these. I have been wanting to have some hi/locuts...
Michael
Gold
« Reply #181 on: May 27, 2009, 07:19:46 AM »
I'm graphically challenged ;) I could scan it and send it to you. It folds out and would have to be scanned in a few pieces.
They are 18 dB/oct. I use them every day and find them very useful and very good sounding. I would be very enthusiastic to see boards done. The switches have an odd form factor and would be difficult to replace. It would be nice to remake them with currently available parts.
zayance
« Reply #182 on: May 27, 2009, 10:04:52 AM »
Is there any way of getting PCB for this project?
signalflow
« Reply #183 on: May 28, 2009, 12:06:56 AM »
Read this thread
http://www.groupdiy.com/index.php?topic=10776.0
-Casey
The shortest distance between two places is a nap.
zayance
« Reply #184 on: May 28, 2009, 08:18:47 AM »
 :-[ i missed that one, thanks.
skal1
« Reply #185 on: May 28, 2009, 08:02:08 PM »
Hi
did you get the chance to  scan that schematic of HT75 HPF/LPF ,i would like to build a dedicated HPF/LPF thingy
 Bless
skal1
outoftune
« Reply #186 on: May 30, 2009, 03:32:13 PM »
Hi
 Bless
skal1
highly interested in this as well. i have a friend who was asking about building some hpf/lpf's for him. i'd love to have some as well. if someone made a pcb, i'd buy quite a few.
outoftune
« Reply #187 on: May 30, 2009, 03:39:30 PM »
also, not sure if TAW still has the pots in stock, but i did an order with all the resistors and caps from TAW. if anyone is building the w492, you can get everything expect the trim pots and opamps from TAW.
Gold
« Reply #188 on: May 30, 2009, 06:26:11 PM »
I can scan it and send it to someone who can stitch the pieces back together and post it. Any volunteers?
« Reply #189 on: May 30, 2009, 07:49:15 PM »
Not a graphic wonder, but i'll give it a try.
Gold
« Reply #190 on: May 31, 2009, 02:41:54 PM »
I'll scan in on Monday. Send me your email address and I'll send it to you.
« Reply #191 on: June 01, 2009, 11:00:06 AM »
Your inbox is full, but the email link in my profile should work.
You can send it there.
jarlehal
« Reply #192 on: July 20, 2009, 07:25:47 PM »
Folks. I promised you my front panel (sticker) files a while ago. But then I couldn't find my memory stick.
Now, guess what!?! It turned up here the other day.
So here I give you my modest artwork. I used an app called InkScape. A great open source project.
http://www.jarlemari.com/diy/w492.svg
If there's interest, I have made some for my other projects aswell. I could host them on my web page.
I used the Sfernice pots btw.
iangomes
« Reply #193 on: July 29, 2009, 01:53:14 PM »
are the boards gustav offers spaced for sfernice or omeg? just ordered some boards, need to get going on the pots.
thanks.
EDIT: i'm guessing by the timeline of the discussion that gustavs boards are the original with the 5.08 spacing. the 7.5mm board gerbers seem to have been posted later on. but, please correct me if i am wrong.
Same question...
stereokillah
« Reply #194 on: July 29, 2009, 02:53:48 PM »
the gustav pcb isspaced for P11 vishay like sernife.
you can put it the omeg also but you need to twist the pin
if your neighbour is hunger .. don't give him fish, teach him how fishing ...
iangomes
« Reply #195 on: July 29, 2009, 02:55:21 PM »
Thank you my good man!
daggertX
« Reply #196 on: August 02, 2009, 09:10:16 PM »
does it matter if the p11 pots are log vs linear?
stereokillah
« Reply #197 on: August 02, 2009, 10:10:29 PM »
10KLIN PA11QXF
it is in tha bom.
« Reply #198 on: August 07, 2009, 11:47:33 AM »
So I've finished this very nice project (Neuman W492 ;) ) but i have some trouble with the first filter. when i turn the P1 clockwise I get some very ugly pops. on the scope it looks like maybe some DC  or some very powerful distortion.
When i back it of a little is disapearing. I useing a tune for testing so its every time the bassdrum get's hit.
I sounds like the filter is ok, cause I can hear the "sweep"
The other three filters is ok - and sounds very good.
I'm using an unbalanced test signal from my soundcard ( pin1 + 3 to ground) is that a problem?
I have regulated the PT1 to 100 ohms before soldering.
I've checked for soldering bulbs, chacked the resistors (i used 619 ohm isted of 620 ohm - should be ok)
I've changed the NE5532.
I'm running out of ideas here.
TIA
Anders B
« Last Edit: August 07, 2009, 12:01:13 PM by AndersB »
2 x 1176, 1 x G9, 1 x Gssl, 1 x real Mctube preamp + +20 Stompboxes
stereokillah
« Reply #199 on: August 07, 2009, 01:57:32 PM »
hello which potentiometer do you use for , perhaps you could see on this side
Last post July 16, 2005, 05:16:38 PM
by verbos
Last post July 27, 2009, 10:34:56 AM
by cuelist
Last post December 11, 2011, 02:15:13 PM
by backstreets
Last post September 24, 2019, 03:25:18 AM
by duende
