Re: Neumann W492 equalizer DIY project (PCB docs added)
« Reply #280 on: January 07, 2010, 04:28:42 PM »
They will work without being mounted, it'll be a bit ugly but they'll work. I have a layout that 'should' work for omeg pots, haven't finished nor tested it yet but going by my measurements and datasheets it should be good.
sirzodiac
« Reply #281 on: January 07, 2010, 05:32:20 PM »
don't forget the first post of this thread: audiox also posted gerbers for a omeg version. just not working in purusha's case, every layout won't work there, because of the (omeg) pot's geometry...
« Reply #282 on: January 08, 2010, 01:09:39 PM »
Does it involve bending the leads over the top/bottom of the board to get the pots more compact? I thought to try this, but no time yet..
Moses
« Reply #283 on: January 09, 2010, 11:35:37 AM »
Almost got the first of 2 of these boxes working... (Waiting on power supply!)...  ;D
I ended up using tat's case with the Vishay pots, It's ended up being a bit of a bodge: Drilled out front panel cut outs to 7mm, and attached the mounting plate using only the pot/switch nuts as spacers. This works fine, and Elma knobs will hide the front panel bodge nicely!!
Mo
dagoose
« Reply #284 on: January 09, 2010, 01:58:49 PM »
Just wondering:
has anybody here done this EQ with stepped swithes instead of pots?
I want to build mine with 12 steps lorlins or maybe even 24 steps to use it for mastering but i'm not sure how to do it.
The gain is no problem, i just need 0.5db steps up and down and last steps at 1db but what about frequencies? I don't need an overlap in the mid frequencies so the ranges can be a bit more cut down.
Anyone?
Da Goose Music Mastering http://www.dagoosemusic.nl
« Reply #285 on: January 11, 2010, 09:13:53 PM »
Hey guys, I've got my design for the omeg pots pretty finalized. I still don't have the chassis for this yet so I did a cardboard mount to test it out. I'll post a few photos and the layout. I'm making a 4 channel in 3U design for myself, I can give anyone that wants the illustrator file it if they want.
« Reply #286 on: January 11, 2010, 09:14:40 PM »
another pic
« Reply #287 on: January 11, 2010, 09:15:00 PM »
last pic
outoftune
« Reply #288 on: January 12, 2010, 10:38:20 AM »
hey, that looks great. would you be able to send me that file in illustrator and jpeg?
« Reply #289 on: January 12, 2010, 11:49:07 AM »
hey Ben,
there is a "share your front panel thread" here:
http://www.groupdiy.com/index.php?topic=33888.0
cheers,
d
« Reply #290 on: January 12, 2010, 12:43:50 PM »
UPDATE: I fixed up my front panel, accidently did 270 degress instead of 300
Here's the illustrator file. http://benlindell.com/diy/W492%20to%20Laser2.ai
« Last Edit: January 29, 2010, 01:48:10 AM by benlindell »
outoftune
« Reply #291 on: January 12, 2010, 08:06:20 PM »
great ben, thanks so much!
does the case you are using have the 2nd front panel for mounting the pots to or are you just using a normal rack case with the single front panel.
what knobs are you planning to use for the omegs?
« Reply #292 on: January 12, 2010, 08:11:42 PM »
I'm no frills and just mounting them on the single front panel.
I bought a bunch of knobs from mouser, couldn't find any good 4mm knobs so I'm just wrapping some metal around the shaft and mounting them. mouser part #s 450-2040, 450-2050, 450-2060, 450-2070
outoftune
« Reply #293 on: January 12, 2010, 09:21:48 PM »
great stuff.
when you say "wrapping some metal" around them...what exactly are you using?
« Reply #294 on: January 12, 2010, 09:26:11 PM »
Haven't done that part yet, planing on getting the thinest sheet of metal I can find and cutting it into small strips.
« Reply #295 on: January 12, 2010, 09:59:47 PM »
You could order knobs direct from Sifam for not too much money, and get all the little colored caps and all.
glazer56
« Reply #296 on: January 21, 2010, 04:13:28 AM »
Greetings! noob question, but...
Can anyone point me to the math for calculating cap values to change the frequency? Scratching my head a little trying to analyze the schematic.
Cheers!
« Reply #297 on: January 21, 2010, 11:09:51 AM »
Google "State Variable Filter" or "State Variable Filter equations".
glazer56
buschfsu
« Reply #299 on: January 24, 2010, 10:02:33 PM »
guys i need some help...
i have a pair of these eqs ready for the purusha case i bought.  problem is these omeg pots are not going to work with this case.  i need the sfernice pots.  so the omegs are for sale and i need the others.  audiomaintenance has them but they come out to 240$$$ usd...ouch.  anyone know of a better price on these in the us?
thanks
PRR said...
OHM'S LAW. Not as an abstract thing: you should be able to glance at a small circuit and "instantly" know I and V, the way a soccer player glances at the ball and knows the angle and kick
Last post July 16, 2005, 05:16:38 PM
by verbos
Last post July 27, 2009, 10:34:56 AM
by cuelist
Last post December 11, 2011, 02:15:13 PM
by backstreets
Last post September 24, 2019, 03:25:18 AM
by duende
