Resistor value change for SSL clone
Chrome Heart
USA
First I would like to say have I have read this entire thread and its been very helpful.
One thing is still a bit unclear though, when using the THAT 2180 LB VCA should the 1M resistor be omitted or replaced with a different value? I have read everything from using a jumper to a 680K or 220K resistor.
I searched "SSL 2180".....hope this helps.
http://www.groupdiy.com/index.php?topic=358&highlight=ssl+2180
Just leave it out. Turn your pcb over and you'll notice that the 1M resistor is only needed if you use the distortion trimmer (Not the 2180)
