mitsos
- Joined
- May 4, 2007
- Messages
- 2,886
update: OK, this thread is getting old. I have been trying to complete these pres since July, and finally got both channels working but still got some grounding issue (HUMMMM).. see later posts... thanks to everyone who's helped out..
OK, so, this is my first build, and I finally got the thing together. Sort of. Right now it looks like the son of frankenstein (metalwork is killing me) and I get no audio output from it at all. As soon as I turn it on (actually 1-2 seconds later) all I get is a hum, and a bit of hiss in the background, with a mic connected or not. Could this be a ground issue? Everything looks ok, but... obviously something's wrong.
Last night when I first tested it, I had the pot wired all wrong. I forgot Ra and Rb, and grounded it like a volume pot instead of wiring like a vari resistor. My first clue is that gain didn't change, the pot just hissed and crackled and stuff. I should have checked the schematic first. Maybe this messed things up? I got that sorted (now it raises and lowers the HUM, albeit like a very bad pot, hissy, scratchy, sound cuts out while moving), but once left in place the pre gives the same noise as last night.
Also, last night I was getting 1-1.5V DC on the output pin 2. Pin 3 had nothing. Just checked again and it was close to zero (+_.002V)
My ground wiring (I admit I don't really understand grounding as well as I should):
The audio input ground (on the PCB) is going to input pin 1, which was grounded with ouput pin 1 to the star ground. I lifted this but had the same hum.
The audio out ground on the main PCB goes to the ground of balance board input.
Balance out ground goes to output Pin 1, which goes to the star ground along with input pin 1.
The 0V from PSU all go to star ground separately.
The 0V from both mainboard and balance go to star ground.
Could this be anything else? I have more 5534s, I figure I could start pulling them out and replacing one by one, but I don't have any way of knowing if one is working or not, so it seems kind of like roulette. Is there an easy way to test these?
So far the only thing I know works is my PSU. I get all the right voltages within .25V.
I think that's it for now, if someone has an idea, I appreciate it.
Thanks in advance..
Thanks in advance..
