pm1000 oscillation / motor boating problem
outoftune
canada
i am just finishing up racking 4 pm1000 modules in a 1U rack.
the first 2 channels (built from master modules) are working fine and sound great.
the 2nd two channels (built from the echo modules) have some problems. when i turn the gain up all the way, they will oscillate/motor boat and spew squealing noises. i have tried a few different things with the grounding but haven't had any luck. they sound good until they get turned up and start to go wild.
it is strange because i have them wired exactly the same way, same signal path.
anyone have suggestions on what to look for? is there something with the grounding? i have it connected in a star ground and am using the external PSU for some other pm1k's I have (they work fine).
Motorboating is usually power supply related.
The preamps used in PM-1000 can be unstable if the inputs are not terminated in a low impedance (the reverb bus).
I'm not sure what use a PM-1000 reverb bus amp is, outside a PM-1000.
the echo module has the "almost" the exact same gain block as the mike preamps/master section etc....i just realized now that it has a few value changes for the gain block in the master section...maybe this is my problem...i will try that.
when you say that is is a power supply issue, as far as motorboating, is there anything in particular to look for/check?
when i checked the boards with the scope/function gen before I install them in the rack, i didn't see this problem. which leads me to believe it's something from the hook up.
thank you for the reply PRR.
