KDE
Re: HairballAudio: FET/500 on sale now!
« Reply #1080 on: May 12, 2019, 12:42:48 AM »
I can't speak for Hairball, but the new FET/RACK was designed as a whole rather than PCB + Case. Unless your case was designed specifically for the new FET/RACK boards they are unlikely to work correctly. Crucially, two of the three brackets at the back of the board are for chassis and signal ground while all three aid the structural integrity of the finished unit.
I two have my own case. Is there any left over stock on the old style pcbs? Would love to grab some Rev A boards
Some things are best left unsaid
Hairball Audio
« Reply #1081 on: June 03, 2019, 01:46:57 PM »
https://www.hairballaudio.com/catalog/parts-store/old-style-fetrack
Hairball Audio, LLC
DIY Parts and Kits
https://hairballaudio.com
Top secret stuff and upcoming releases:
http://instagram.com/Hairballaudio
http://facebook.com/hairballaudio
Fuzz Face
Re: Hairball Audio, LLC - DIY Kits and Components. HairballAudio.com
« Reply #1082 on: June 06, 2019, 07:32:02 PM »
I built a FET/500 rev A a month or two ago and just wanted to say I have really been loving it.
I love how it sounds even in GR off mode. The 2:1 ratio is getting used all over the place. Slam mode is everything I hoped for on a drum room mic.
You guys are great. Thanks for the amazing kit (and free T-shirt)
I see a Rev D pair in my future :)
Hairball Audio
« Reply #1083 on: June 06, 2019, 07:36:28 PM »
Hairball Audio, LLC
DIY Parts and Kits
JW
« Reply #1084 on: January 12, 2020, 09:40:18 AM »
Is there any difference between the EA1166 (original) and the newer EA1166 500 series, other than the size? I guess I'm wondering if compromise was necessary? Or it's the same attention to the original LO1166?
Hairball Audio
« Reply #1085 on: January 13, 2020, 05:18:49 PM »
IIRC Ed had said it might have slight more low-end THD.
Hairball Audio, LLC
DIY Parts and Kits
JW
« Reply #1086 on: February 17, 2020, 03:14:01 PM »
How does one hook up the EA1166 transformer to neve circuit? I see the pdf on the hairball site, but I'm still confused about the wiring compared to original schematic.
I have two of the older (larger EA1166)
For the primary, orange and yellow tie together? Brown or Red goes to the +24V ("M" on the BA283 schematic)
On the secondary, there's usually the 1.5K and .01uF cap in between the hi and lo outs.
So, for a 600 ohm out tie blue and purple together and use green and grey correct? But which is hi and which is low (and which connects to the resistor, which to cap?)
Hairball Audio
« Reply #1087 on: February 17, 2020, 04:09:49 PM »
Yes orange and yellow are tied together to make a series connection.  Brown is the start of the winding and is pin 1 (connects to B) on the schematic and Red connects to M.
Secondary is series so tie blue/purple together, Green (pin5) is hot and grey (pin 8) is cold.  Zobel across the secondary and shown on the schematic.
Hairball Audio, LLC
DIY Parts and Kits
