API 312 Scans
« on: June 09, 2004, 09:46:58 AM »
Here are some API 312 Scans
Seth
The definition of insanity: "Hey, this thing could be really cool - if I had the money to fix it up, which I don't, but if I did it could be really cool - if I had the time, which I don't, but
laitue5
API 312 Scans
« Reply #1 on: June 09, 2004, 09:50:56 AM »
Nice job ! thanx !
metal film 1/4W is ok
SSLtech
API 312 Scans
« Reply #2 on: June 09, 2004, 10:29:31 AM »
Seth...
Can we possibly have some accurate overall dimensions.. in inches and mm for those in different regions. -Cheers!
-Any objection to me making a plot of this and pdf-ing it?
Keith
"A waist is a terrible thing to mind"
Quote from: PRR
Ah, but that was 1999; we don't party like that any more.
API 312 Scans
« Reply #3 on: June 09, 2004, 11:37:32 AM »
Keith,
I'm not at home, but I'll post the dimensions as soon as I get home. I also already have an accurate pdf, so I'll post that as well. :thumb:
Seth
Bauman
API 312 Scans
« Reply #4 on: June 09, 2004, 11:41:07 AM »
I'd like to make a gerber version of this, then a PDF sohuld be easy to output also. But I too need the dimensions... :)
cheers!
Fabio
cheers!
Fabio
_____________________
www.thediypill.com/store
API 312 Scans
« Reply #5 on: June 09, 2004, 12:27:04 PM »
OK, no problem. Later today.
Seth
fum
API 312 Scans
« Reply #6 on: June 09, 2004, 12:41:03 PM »
Da-Zing!
Thanks Seth!
CJ
API 312 Scans
« Reply #7 on: June 09, 2004, 02:10:29 PM »
I can do the same thing with the Melcor PCB if anybody is interested, the whole board, not the opamp circuit board.
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
fallout
API 312 Scans
« Reply #8 on: June 09, 2004, 02:27:07 PM »
That'd be wicked CJ, I'd love to compare it to the layout we are currently using! Thanks!  :guinness:  :sam:
-Jay
CJ
API 312 Scans
« Reply #9 on: June 09, 2004, 02:36:58 PM »
You mean the small actual Melcor board, or the one it gets plugged into?
I meant just the big board , just to clear up any confusion.
cj
Bryson
API 312 Scans
« Reply #10 on: June 09, 2004, 04:31:26 PM »
Remember that folks like BA modify these to match the newer pinout of BA and API frames.
adrianh
API 312 Scans
« Reply #11 on: June 09, 2004, 04:36:11 PM »
Gerbers are cool.
We need more for all projects.
fallout
API 312 Scans
« Reply #12 on: June 09, 2004, 05:22:06 PM »
Ahh, thought you were talking about the 1731!  Sounds good anyway.. :guinness:
API 312 Scans
« Reply #13 on: June 09, 2004, 06:43:13 PM »
Keith,
The board is 2.76" x 4.26" (70mm x 108mm)
The transformer cutout is  1" x 1.32"  (25mm x 33.5mm) and is .42" (10.5mm) from the bottom edge and also from the back edge.
The edge that fits into the connector is 2.5" (63mm)
The transformer screw holes are 1/8" (3mm) in diameter.
Need more?
Here's the pdf:
http://sethglassman.com/312Rev.pdf
Seth
fum
API 312 Scans
« Reply #14 on: June 09, 2004, 07:49:06 PM »
DaJing! You so totally rock, squirt! Gimme some fin! Noggin! :thumb:  :thumb:
API 312 Scans
« Reply #15 on: June 09, 2004, 10:53:17 PM »
Enjoy! :guinness:  :sam:  :thumb:
Seth
dukasound
API
« Reply #16 on: October 25, 2004, 04:57:21 PM »
Hi I redrawed old Api board helped with Seth scaned one.
I need dimension of pins raster.
I will send pdf or cdr on site when I be sure.
I made one for original 2622 and one for OEP.
Here is one working pcb with OEP:
http://www.cankar.net/duka/API_Original_pcb_OEP.pdf
Duka
dukasound
Re: API
« Reply #17 on: October 27, 2004, 05:55:11 AM »
Hi
Here is final redrawned pcb for both 2622 and OEP.
http://www.cankar.net/duka/API_pcb_2622+OEPfin.pdf
I worked in Corel 11 and you can open this file.
Thanks to Seth and Peter for original dimensions for card and connnector.
If anyone have two spare 15 pin connectors let me know.
Duka
API 312 Scans
« Reply #18 on: October 27, 2004, 08:53:25 AM »
Wow, that looks great Duka.
Can you do the same thing for CJ's AM-16 board pictures?
 :thumb:  :thumb:
Seth
dukasound
API 312 Scans
« Reply #19 on: October 27, 2004, 11:01:17 AM »
Quote from: "jrmintz"
 :thumb:  :thumb:
I will look that!
I need dimension of board and some measuring
Need two spare 15 pin connectors :?:
Duka
Last post December 05, 2005, 10:41:46 AM
by raysolinski
Last post January 09, 2012, 09:05:51 AM
by zaichornok
Last post July 18, 2019, 02:47:05 PM
by fazeka
Last post May 28, 2020, 11:20:59 AM
by wlinart
