owel
API 312 Scans
« Reply #20 on: October 27, 2004, 11:18:09 AM »
Is there a component placement guide for this board? and parts list?
dukasound
Re: API
« Reply #21 on: October 27, 2004, 11:19:03 AM »
dukasound
API 312 Scans
« Reply #22 on: October 27, 2004, 11:19:59 AM »
Quote from: "owel"
Look original Api schematic!
CJ
API 312 Scans
« Reply #24 on: October 27, 2004, 05:30:29 PM »
The Langevin AM-16 board is about 1 and 1/2 inches by 5 and 1/8 inches.
We have at least one person who is working on it.
cj
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
drpat
API 312 Scans
« Reply #25 on: May 16, 2005, 03:28:38 AM »
« Last Edit: September 17, 2010, 08:52:47 PM by drpat »
I use the LA2a on very hot signals like lead vocal.
312 pcb
« Reply #26 on: May 11, 2006, 02:00:38 PM »
Is there any APi312 pcb's for sale to fit in a 500 rack  :?:  :?:  :idea:
soundguy
Re: 312 pcb
« Reply #27 on: May 11, 2006, 02:02:32 PM »
Quote from: "thestudio"
http://www.groupdiy.com/index.php?topic=15064
chips are good with dip...
500 rack
« Reply #28 on: May 19, 2006, 01:14:54 PM »
$120 is steep......
API 312 Scans
« Reply #29 on: May 29, 2006, 12:41:08 AM »
Quote from: "jrmintz"
Keith,
The board is 2.76" x 4.26" (70mm x 108mm)
The transformer cutout is  1" x 1.32"  (25mm x 33.5mm) and is .42" (10.5mm) from the bottom edge and also from the back edge.
The edge that fits into the connector is 2.5" (63mm)
The transformer screw holes are 1/8" (3mm) in diameter.
Need more?
Here's the pdf:
http://sethglassman.com/312Rev.pdf
Acrobat gives me a corrupt file error when I try to download/open the PDF can you re-upload it?
API 312 Scans
« Reply #30 on: May 29, 2006, 10:30:16 AM »
Brad,
I just tried from the url in your quote and it worked fine...
Try again and if it still doesn't work PM me.
Seth
The definition of insanity: "Hey, this thing could be really cool - if I had the money to fix it up, which I don't, but if I did it could be really cool - if I had the time, which I don't, but
livingnote
Re: API 312 Scans
« Reply #31 on: December 15, 2009, 11:20:09 AM »
So where did this go? I just etched one and thought I'd take it in over by Volker's place to check
for compatibility with the 500 series...got my attention because someone went peep about wanting
a board, and considering it's fairly simple to translate, why not make some?
Quote from: emrr
F-in' hook some Sh*t up and see if it catches on fire
Living Note Studio
Re: API 312 Scans
« Reply #32 on: October 01, 2020, 09:04:07 PM »
Hi
Probably a stupid question at this point in history but, I'm tooling up to make a couple of these and the board has 6 input transformer holes but almost all the available transformer options have 8 pins. Would anyone be kind enough to tell this fool what I am missing?
Thank you!
Whoops
Re: API 312 Scans
« Reply #33 on: October 05, 2020, 09:54:17 PM »
Hi
Thank you!
I already posted that question in your other thread.
This doc might be interesting in 2004, in the beginning of this forum, I don't see why do you want to do that layout in 2020.
There's no provision for Gain, output attenuation, Polarity reverse, Pad or phantom on that board.
Nowdays there's modern layouts around this forum much more interesting for the 312
Last post December 05, 2005, 10:41:46 AM
by raysolinski
Last post January 09, 2012, 09:05:51 AM
by zaichornok
Last post July 18, 2019, 02:47:05 PM
by fazeka
Last post May 28, 2020, 11:20:59 AM
by wlinart
