API 312 Scans
jrmintz
NY
Here are some API 312 Scans
Seth...
Can we possibly have some accurate overall dimensions.. in inches and mm for those in different regions. -Cheers!
-Any objection to me making a plot of this and pdf-ing it?
Keith
Keith,
I'm not at home, but I'll post the dimensions as soon as I get home. I also already have an accurate pdf, so I'll post that as well. :thumb:
I'd like to make a gerber version of this, then a PDF sohuld be easy to output also. But I too need the dimensions... :)
cheers!
Fabio
That'd be wicked CJ, I'd love to compare it to the layout we are currently using! Thanks! :guinness: :sam:
-Jay
Keith,
The board is 2.76" x 4.26" (70mm x 108mm)
The transformer cutout is 1" x 1.32" (25mm x 33.5mm) and is .42" (10.5mm) from the bottom edge and also from the back edge.
The edge that fits into the connector is 2.5" (63mm)
The transformer screw holes are 1/8" (3mm) in diameter.
Need more?
Here's the pdf:
http://sethglassman.com/312Rev.pdf
Hi I redrawed old Api board helped with Seth scaned one.
I need dimension of pins raster.
I will send pdf or cdr on site when I be sure.
I made one for original 2622 and one for OEP.
Here is one working pcb with OEP:
http://www.cankar.net/duka/API_Original_pcb_OEP.pdf
Duka
Hi
Here is final redrawned pcb for both 2622 and OEP.
http://www.cankar.net/duka/API_pcb_2622+OEPfin.pdf
I worked in Corel 11 and you can open this file.
Thanks to Seth and Peter for original dimensions for card and connnector.
If anyone have two spare 15 pin connectors let me know.
Duka
Wow, that looks great Duka.
Can you do the same thing for CJ's AM-16 board pictures?
:thumb: :thumb:
[quote author="jrmintz"]Wow, that looks great Duka.
:thumb: :thumb:[/quote]
I will look that!
I need dimension of board and some measuring
Need two spare 15 pin connectors :?:
Duka
