I'm working on a circuit design just now, and am trying to use these as simple gain stages in triode mode:
http://lab.artematrix.org/electronics/datasheet/VALVE/1J24B.pdf
At the moment I am trying to run the valve on a 9V battery which I was using successfully with another low-powered valve - the 6418, so B+ is 9V and heater is 1.2V or so.
As it is just now, the valve is only passing a small distorted signal only when the input is high which sounds a bit like a valve which is biased too cold, or missing a grid-leak resistor for bias.
I've made the assumption that like the 6418, this valve is biased via the heater voltage since there is no separate cathode connection, but this is what I am wondering if I may be wrong. Does anyone have any ideas?
The fact that the datasheet is in Russian doesn't help me.
Roddy
Roddy
