woofer used in Dynaudio BM6a monitor
radiance
the Netherlands
In the back of my mind I know this has been asked here before but a search did not bring much results .....:sad:
Does anybody know what brand & type woofer / speaker is used in the Dynaudio BM6a monitor? On the speaker itself there only is a Dynaudio serial number and I suspect this to be a fairly common speaker. Might be cheaper to not buy it as spare part from Dynaudio ...
hello radiance,
the woofer is not a cheap one, it's made by dynaudio and is one of the best woofer made.
there's a standard model 15w75, but think the one in the bm6 is purpose-built.
look:
http://www.gattiweb.com/dynaudio.html
so, I guess you need to contact dynaudio maybe
best
maxime
I think (not sure, but you can check if it has similar basket) the woofer is 17WLQ ESOTEC, and indeed you can buy a new one from Dynaudio (if you have the serial forf the BM6a's). It might be possible to find similar driver in some car speaker kits, but they may have a tailor parameters for car use (or may not, who knows). This is the car part:
http://www.dynaudiousa.com/products/car/drivers/160.htm
Notice that it's 4 ohm driver.
