Snatchman
Hello. I aquired this 4-channel DI and it sounds pretty good. It seems to be a tad noisey compared to my other DIs tho... :sad: ... I opened it up and see it has socketed 8 pin op-amps. ( TL071s and 5532s ).. Do you think they may contributing to the noise? If so, what op-amps could be used ( direct replacement) to swap out to lower noise? Anyone have these replacements they would be willing to sell me since I'll only need 8?.. ( 1 for in x 4 / 1 for output x 4)... :green: ..BTW...is there a special tool used to remove/install socketed op-amps other than just grabbing them buggers with your fingers?.. ...Lastly, I also noticed that there's a lot of room inside this chassis.. Wonder could output transformers be added to it... :idea: .... BTW..it has some pretty cool features..Thanks......
