SSL Clone Bridge Rectifier
Chrome Heart
USA
Does anyone know if substituting a 600v Bridge rectifier in place of the 400V will make any difference? Digikey is out until Nov. and as long as I have an order going on Id like to get everything.
nope, it does not matter. just means that the 600V will handle more voltage.
just be sure the bridge rectifier you are getting can handle the same current as the rectifier that is spec'd and fits the same footprint (so it fits nicely on the board). only problem is that sometimes the legs are a bit thicker on larger/higher spec'd rectifiers, but if it's about the same voltage it should be o.k. double check the datasheet for leg thickness.
regards,
grant
