[quote author="dinesh"]Hi All,
Thanks for your suggestions. Tomorrow, I am going to place the order for 8 Core Mac Pro.
So What next?
Logic
Or
Pro tools LE.
DAW I need is for Audio Mixing, Editing. Midi is not a priority. I want a good sounding Engine with nice Plugins.
I want 24 (Minimum 16) analog outs. I know Protools LE has only 18 outs. 8 analog + 8 Adat light pipe. Can do with this. Is M-Powered Pro-tool is same as Digidesign's LE?
Looking for more suggetions
Regards
Dinesh[/quote]
Even though you want to mix more than use midi, Logic studio is a good
choice.
Great plugins and automation make it a breeze to mix in and you can just
buy the I/O of your choice - too many to chose from.
AU plugins and things like the new UAD-2 / URS and Soundtoys will mean
outstanding results.
If you need to get PT or you like that platform, fine .. and "Beat Detective"
is worth having .... perhaps in addition to Logic as a small alternate system.
I used to use Nuendo on mac which was quite good but I don't know if it's
still supported ??
Any other systems such as DP and Reaper I don't know much about.
MM,
