Barbera Media
I purchased 2 of the Gpultec pcb's a couple of months ago and while my initial intention was to build the eq's the boards were originally intended for, i couldn't help but research more about "srpp" and exactly what it is/does. I have recently started compiling ideas for a small, simple mixer using passive summing. With that being said I have 2 questions i haven't been able to find the answer to. Does anyone know if the SRPP pcb could be used as the make up gain amplifier for the passive summing network? Would only the input transformer need to be changed and bridge the in/out where the filter pcb's connect? Also in passive summing, I'd like to make a balanced network, only inserting faders for level control. Would these faders replace the resistor network or would the faders be in addition to the resistors? Looking forward to seeing where this goes.
