peterc
Re: S800 Support Thread
« Reply #720 on: May 19, 2016, 01:40:03 PM »
Hi Neil
Nope, these are the original boards, not the 500 series PCBs
Peter
If opportunity doesn't knock, build a door.
Le Roux
« Reply #721 on: May 19, 2016, 02:32:20 PM »
Thanks Peter.
I am interested in a pair if there's some extras.
I will keep an eye on this thread
Neil
« Reply #722 on: May 26, 2016, 11:10:53 PM »
I'd also be up for a couple of boards. Thanks.
peterc
« Reply #723 on: June 03, 2016, 01:58:16 AM »
Hi all
Boards are now available in the White Market
http://groupdiy.com/index.php?topic=62900.0
Regards
Peter
« Reply #724 on: June 07, 2016, 02:42:12 AM »
With Peter making PCBs again, anyone going to have front panels?
"Kind of like going into Safeway at 4 in the morning and chugging a beer in the produce section; been there, done that." - CJ
"We're not making an atomic bomb, just cooking a few electrons." - PRR
JW
« Reply #725 on: June 12, 2016, 07:39:48 PM »
Finished a 4 channel unit
« Last Edit: June 12, 2016, 07:43:07 PM by JW »
JW
« Reply #726 on: June 12, 2016, 07:43:40 PM »
And the guts
JW
« Reply #727 on: June 12, 2016, 07:56:10 PM »
And a question. I'm a little confused as to how to hook these up to my consoles send/return jacks. I've attached a schematic. It's a Yamaha PM2000, and the send/return is listed as "input interstage" in the top right of the schematic.
According to yamaha literature, these are 600 ohm sends (I can't remember the returns input impedance) But anyway, there's no transformers. Just unbalanced send and return.
Here's the handy Rane literature about system interconnects: http://www.rane.com/note110.html
Looks like figure 13 would be right going into the S800's from my sends,
and figure 3 or 5 (?) would be correct coming out of the S800 and into my returns?
Can someone confirm this?
peterc
« Reply #728 on: June 13, 2016, 10:13:56 AM »
Hi JW
13 looks good for the sends to the S800.
5 looks right for the returns, but I would not join 1 + 3 on the EQ output.
Peter
TDRS
« Reply #729 on: June 30, 2016, 01:45:14 PM »
. How about just a template if there are no cases or front panels.  I noticed most of the docs and templates from this thread are so old the links no longer work.
« Reply #730 on: July 02, 2016, 05:38:47 AM »
+1
« Reply #731 on: August 06, 2016, 09:52:17 AM »
Are there any boards left for sale? Cant find white market thread..
TDRS
« Reply #732 on: August 14, 2016, 05:37:59 PM »
I'm just getting started with these boards. I downloaded the schematic but it's such a low resolution I can't read it. Is there a high resolution schematic other than the one in the download section for docs here. My problem is R41 and R42. Heres a pic, I see 3 resistors positions, is 1 and 3 R41 and R42? If so, whats #2?  I can't read where the pin hole goes through the board. Any tips?
TDRS
« Reply #733 on: August 14, 2016, 05:48:10 PM »
I see now that it's a link. So is it 1 is R41, 2 is a link and 3 is R42?
peterc
« Reply #734 on: August 14, 2016, 06:05:03 PM »
In this case:
1 = LK = oR link
 2 = R41 = 47k
3 = R42 = 47k
Hope that helps.
Peter
TDRS
« Reply #735 on: August 14, 2016, 10:35:09 PM »
It does indead. Thanks Peter.
« Reply #736 on: November 07, 2016, 01:04:00 PM »
Just got my kit from Colin, though it didn't include the push button 4 pole switch. Anyone know of a Mouser part for this? Or where to order one? Thanks.
« Reply #737 on: November 27, 2016, 01:50:12 AM »
Yeah, I'm putting my S800 together soon and spent a good chunk of yesterday trying to sort the switches out.  Part number is SPUN194700 and they're inexpensive, but you have to buy the switch caps separately. Part number UE200011 (Black), UE200013 (white), comes in other colours too. I found here in the UK that Mouser wanted £33 of goods purchased before free shipping and from what I remember there's a flat rate of around £12 - £15 otherwise. I may be wrong about that as it's been a while since I ordered anything from them, but too much for a few quids worth of switches. At least they sell the switch caps though, unlike R.S and some of the other big companies (I think I checked Farnell & Canford aswell). Kinda odd to sell the switches but not the caps ????.   Colin also sells  SPUN switches, dunno about the caps, didn't see any on the website. So in the end I ordered a couple of 3PDT toggle switches as part of an order from Banzai. Oh well. Hope you have better luck..
craigmorris74
« Reply #738 on: February 19, 2017, 09:28:12 PM »
Greetings folks,
I few years back I built a couple of these, but when I hooked them up, I wired one of the power supplies backward (+ to - and vice versa) and blew up one of the electrolytic capacitors.  Upon further testing, I noticed this channel is still pretty noisy-it sort of sounds like the ocean when inserted.  Rather than recap the whole board, I was wondering if there was a certain electrolytic cap that would most likely be causing my noise problem.
Craig
peterc
« Reply #739 on: February 20, 2017, 03:10:41 AM »
HI Craig
Were the opamps in at the time? They might be noisy......
The 2 main filter caps both need to be changed, next to the power connector.
Start there, but you might need to do more, unfortunately.
Peter
Last post September 11, 2007, 04:35:55 AM
by pstamler
Last post September 12, 2017, 05:47:24 AM
by alexc
Last post April 28, 2014, 09:48:49 AM
by MaNiAC
Last post August 31, 2014, 04:22:25 AM
by Majestic12
