Bypass relay PCB: available
« on: October 05, 2008, 09:33:39 PM »
Hi to all again!
At this time, most usefull thing in addition to all projects
like GSSL, GPultec, G1176, and many others from this forum.
There are 2 types of boards.
Which board I need? Depending on connectors used and distance between connector's centers; check here:
http://www.groupdiy.com/index.php?topic=29770.msg541523#msg541523
This PCB gives an option for true bypass, cleanest way-
relays contacts only, and it placed close to in/out XLR's.
Can be used in mastering setup as insert's patchbay.
Options:
-Any commercially available DIP-16 relay's can be used
 in parallel or series connection for voltages availabe from
 power supply you use.
-Output XLR pin 1 goes to case thru RC network solving ground issues.
-Input XLR pin 1 can be disconnected from case.
-Load termination resistor and Zobel network preserved for
 output transformers for devices like 1176 or Neve, etc.
-PCB mounted XLR's or Jack's for easy hookup.
-Fits easy in Tat's cases, just ask for backs like Sontec stereo.
Schematic/PCB:
http://i251.photobucket.com/albums/gg291/diy33609/Bypass/BYP_SCH.gif
http://i251.photobucket.com/albums/gg291/diy33609/Bypass/BYP_PCB.gif
More pictures:
http://i251.photobucket.com/albums/gg291/diy33609/Bypass/P1000871.jpg
http://i251.photobucket.com/albums/gg291/diy33609/Bypass/P1000873.jpg
http://i251.photobucket.com/albums/gg291/diy33609/Bypass/P1000878.jpg
http://i251.photobucket.com/albums/gg291/diy33609/Bypass/P1000880.jpg
http://i251.photobucket.com/albums/gg291/diy33609/Bypass/P1000881.jpg
Series relay connection:
http://i251.photobucket.com/albums/gg291/diy33609/Bypass/P1000875.jpg
Parallel relay connection:
http://i251.photobucket.com/albums/gg291/diy33609/Bypass/P1000876.jpg
PCB's and kits are available now.
http://www.groupdiy.com/index.php?topic=29771
Kit contains pcb, xlr's, relays, Molex conn., etc.
Relays supplied with kit are 12V, i.e.
can be can be used on 12 or 24V supply.
It should work fine with allmost all projects.
Example, GSSL: on power supply caps (before 7815)
voltage is approx. 22-24V if 18-0-18V trafo used.
G1176: use 28V, possible to add 47-68R 1W resistor in series with relays to get 24V.
GPultec: there's approx. 12V before LM317 heater's power supply
etc.....
« Last Edit: March 06, 2011, 05:18:02 PM by Igor »
http://www.ij-audio.com
(new site hopefully will be up in July)
analogical
« Reply #1 on: October 05, 2008, 11:04:29 PM »
Hehe oh you know I'll be in for more than a few of these!    :wink:
inputoutput
« Reply #2 on: October 06, 2008, 07:06:18 AM »
YES!! this will actually make my life a littlebit easier
roginator
« Reply #3 on: October 07, 2008, 04:49:01 AM »
wow im in for 2 minimum
Brain is CV controlled device!!!!!! so we all are analog sequenced machines!!!! " ROBOTS "
feza
« Reply #4 on: October 14, 2008, 12:09:55 PM »
Great! I want one kit for the GSSL.  :thumb:
guy_4
« Reply #5 on: October 14, 2008, 05:11:14 PM »
Hello Igor,
Looks like a nice idea and board !
I will be in for a few units   :grin:
Guy
"If you think it is expensive to hire a professional, wait until you hire an amateur ! "   Red ADAIR
« Reply #6 on: October 14, 2008, 09:17:01 PM »
Whoops
Re: Bypass relay PCB: available
« Reply #7 on: November 25, 2008, 11:23:47 PM »
Why would you need to add this to the GSSL?
if the "IN" knob is not pushed you are bypassing it , right?
thanks
SaMpLeGoD
« Reply #8 on: November 26, 2008, 07:41:12 AM »
Yes, but with that board you "hard Baypass" the unit, the signal don't reach the circuit when bypassed, with that relays it wires the in and out directly.. got it? ;)
Eddie  :P
Keep on Rockin' and DIYing!!!!
Whoops
« Reply #9 on: November 26, 2008, 05:04:37 PM »
I probably would get it even more, if I had a look to the GSSL circuit or if I've made one already.
I thought that the In button switched the Input directly to the circuit or directly to the output
sorry for that, and thanks a lot for you explanation.
In the future I hope to build one and then the relay will probably be a must have.
feza
« Reply #10 on: November 27, 2008, 09:00:06 AM »
Hey Igor,
I checked the kits and saw that two 3 pins set are missing? Also looked at the schematic and saw the various options. I'm building the GSSL with Super Sidechain, Turbo, and your relay board. Is there a chance those 3 pins are not needed? Otherwise I will order the Molex connectors elsewhere. And by the way the SSC will be featured, but not at the moment.
I'll be making a thorough wiring setup about this particular build. So any help will be appreciated by you Igor.  :)
Thanks in advance,
Dennis
« Reply #11 on: November 27, 2008, 10:50:10 AM »
Hi, what 3 pin set do you talking about? There's IN, OUT, and BYPASS SW...
You mean, ALL Molex connectors are missing?
For GSSL, 2 boards needed. With 12v relays, I'd connect both boards in series,
relays wired in series, beetween + and - before 15 V regulators.
Schem:
http://i251.photobucket.com/albums/gg291/diy33609/ssl_byp.gif
BTW, some people asked me to make bypass boards which fits regular Neutrik
nc-3 connectors and can be used with all standard Purusha's cases,
60mm beetween Neutriks...
I ordered 100 boards for my purposes.
Are there people interested?
« Last Edit: November 27, 2008, 10:59:37 AM by Igor »
feza
« Reply #12 on: November 27, 2008, 11:02:55 AM »
I'm sorry I was not clear Igor.  But reading your schematic solves it all!  :D
Dennis
feza
« Reply #13 on: December 01, 2008, 12:20:02 PM »
Hey Igor,
I'm planning to build an external PSU board with my GSSL. The one going to be used is Mnats PSU board. Below is some info :
http://www.geocities.com/m_natsume/psu.html
What is not going to be featured on the board are the big capacitors (35v, 1000uF) and the bridge rectifier. Picture from Matta's off-board PSU build (hope you do not mind, Matta  :))  :
So the off-board PSU what I am going to use has trimmers for correct (precise) positive and negative voltages. Are the +15 and -15 rails direct connectible with the relays? Obviously going for the Molex connectors from the PSU to the relays, neat isn't it? If so is there anything to be reminded and be careful with, with this approach?
Thanks for your reply!
feza
« Reply #14 on: December 03, 2008, 03:48:56 PM »
Hey Igor,
Hey,
Well. Looking in my GSSL picture archive I came upon this (uploaded on imageshack, not your webspace Mathflan) :
This is how it should done if anyone (almost complete for me) is waiting for the respons about this particular GSSL setup. However if anything is not correct about the wiring? Let us know. Still this is not the relay what Igor is selling, but an idea how to wire it.
Later,
Dennis
klaus2you
« Reply #15 on: December 10, 2008, 11:44:21 PM »
Hi Igor,
((("BTW, some people asked me to make bypass boards which fits regular Neutrik
60mm beetween Neutriks...")))
I'll be really interested for a few of them, when do you be able to sell some?
Thanks, Adrien.
guy_4
« Reply #16 on: December 14, 2008, 08:17:25 AM »
Hi Igor,
I've sent you a PM about my order of BYPASS pcb's.
Guy
Whoops
« Reply #17 on: December 14, 2008, 12:40:05 PM »
Schem:
I would be into 4 or 6 of those boards.
« Reply #18 on: December 14, 2008, 12:45:12 PM »
No probs. Offered. See my sticky.
When ordering,
Please note which bypass boards you need
60 mm regular or "Sontec".
« Last Edit: December 14, 2008, 12:55:41 PM by Igor »
damien
« Reply #19 on: January 17, 2009, 06:59:41 PM »
Hello,
I was looking for a true bypass kit for a while !
Do I need 1 or 2 kits for a GSSL compressor as it is stereo ?
on the ordering topic you say that it costs 6€ for "a PCB" + 6€ shipping, you don't talk about a full kit.
So, is it delivered with the electronic components or is it just the board ?
Thank you in advance for you answer.
Damien
« Last Edit: January 17, 2009, 07:59:02 PM by damien »
Last post September 30, 2006, 12:55:23 PM
by martthie_08
Last post August 02, 2009, 10:36:57 PM
by tgauge
Last post September 14, 2009, 05:45:47 PM
by JohnRoberts
Last post April 30, 2019, 11:31:09 AM
by Sinkia
