GAC-7 Wiring question...
SaMpLeGoD
Portugal
Hi I'm just finishing my G7 and I'm wiring the 7 pin + Shield cable with Neutrik's 7 pin connectors and 5m of Deltron GAC-7 cable from Farnell...
Well, could somebody put the Wiring Schematic for it? I just couldn't find that anywhere and I'm affraid just to "suspect" the right wires... well, I know that if I got the wires matched at the end, the cable works, but there is different Insulations and wire's sections... and did I connect the cable's shield to the ground pin too?
Sorry the rookie question by the way...
Cheers :guinness:
Eddie :thumb:
The thick wires (red and blue) should be used for the heater supply as it carries a higher current. The others don't matter.
do I connect the cable's shield to the ground pin too?
Yes. (But some people prefer just to connect this at one end to avoid ground loops)
