Viitalahde
Today I hooked up a TO-3 LM338 regulator for 1,8A worth of 6,3v filaments. 2x 6SN7 and 2x 7193.
With the load connected, the raw, rectified & smoothed DC is about 13 volts. This voltage I'm taking from series connected 6,3vac/4A & 5vac/2,1A windings (which is not ideal because of the unbalance, but I wanted to try it before installing another transformer). Capacitance used is 22,000uF.
For some odd reason I just can't get the damned LM338 go past 6,0v with the load connected.
I first had 255ohms as R1 and a 1k pot as R2. Worked fine without the load. After connecting the load, output voltage dropped too much. Then I reduced the R1 to 200ohms, which helped me to get to 6,0vdc, but I'd still like to get more out of it in case I want to dial in a full filament voltage. At 6,0vdc the output shows a small amount of ripple, which almost vanishes when reducing the output to about 5,8vdc.
Here comes the question:
Years ago I remember reading something about R1 & higher currents - the R1 should be made smaller than usual or the regulator won't work properly. I can't find any reference to this, so it might be BS..?
I'm returning to this on monday but I find it strange that with some 7 volts of extra voltage to regulate from, I can't get past 6,0vdc..
