Sleeper
I'm working out a few details, trying to lose the mixer. a passive summing bus and monitor controller takes care of my back end, but I'd like to knock togerther a little switching matrix to move some of my rack effects boxes to different AD inputs.
Here's the idea:
http://pg.photos.yahoo.com/ph/tkell...lbum?.dir=/aca6&.src=ph&.tok=phZ2f8BBkABHP0RH
2 Questions
1. I put the 10k resistors on there in case I want to feed one AD input with 2 effects boxes (this won't be happenning except on rare occasions) and to keep the switches from popping. I just realized in writing this that I made a summing bus and the way I'm implementing this is going to give me way too much combined mix resisitance and gain loss- not what I want.
Hey-thinking out loud can be a good thing.
OK so I'll lose the resistors, mixing these effects is LOW priority...
but can I pop proof a switch like this...
In the end no resistors will just make this work exactly like a patch bay which I can deal with.
2. The grounding. I'd rather use a 2pole switch as it's more readily available and affordable but this means I have to tie the grounds to chassis... Far as I can tell I've got as good a chance of getting a ground loop this way as if I switch the grounds through the system with a 3 pole switch. Any thoughts on this?
Thanks All
Sleeper
Here's the idea:
2 Questions
Thanks All
Sleeper
