I dont mean to flood this forum with such redundant topics but there isnt any info on what im trying to find out and that is my Green pre works very well when I connection a "test clip" to the ferrite bead and the other end of the test clip to star gnd. This causes the mic pre to work very work except when I plug in any type of dynamic mic to the mic pre then I dont get any signal :?
Other than that input xlr pin 2 and 3 connected properly which pin 1 goes to star gnd
output pin 2 to pre and pin 1 to star gnd.
mains safety gnd connected to star
48v switch works properly when its on and off
voltages on NE5534 are close to reference voltages (maybe off by a few volts on each pin)
also in regards to the caps in particular the 4700uf 16v one is that one supposed to measure at a full 16v?
I'm going nuts here but trying to keep the faith :?
