step. atten. DRY-Control for SSL Compressor
matthias
germany / frankfurt
I want to mix dry signal to the compressed signal...
jakob posted a nice mod some time ago, but if you mix
it in the circuit itself, output gain always affects the wet/dry mix setting...
so my idea is to build a simple stepped attenuator around the circuit...
you can set a certain leve of dry signal and adjust the mix with the output gain pot...
the signal goes form the xlr-input to the attenuator to the output-xlr
I have some 2x5 dual stepped switches here... so there will be 4 attenuated steps + off setting... -10db , -6db , -3db , 0
there's a nice java app that calculates the resistance for each step...
http://www.quadesl.com/attenuator.html
but does anybody know at what total resistance I should start??
50k, 100k ??
thanks,
matthias
hey mathias, i like your idea...check this
http://homepages.tcp.co.uk/~nroberts/atten.html
did you ever get your high pass filter happening in your ssl?
If so, I would be interested in hearing more about how that worked out and if you are digging it.
thanks.
Chris
thank you...
yes, the sidechain is working, but I didn't use the 200hz 12db filter....
there's a much more easier solution for this...
I'll post it when I'm at home... (I'm still @ work)
