schmidlin
Federal AM-864 Compressor w/Output Control
« on: November 17, 2008, 01:43:26 PM »
As usual, when I wrap up a new build, somebody asks for another option for it.
I'm looking to vary the output on the Federal, and think I am on the right track.  With all this hemming and hawing over triple stacked variable T pads, Daven attenuator$ and sourcing issues, do any you see why this would not work properly?  (I hope this 'attach' thing works ok)
Thanks in advance.
perception > reality
schmidlin
Re: Federal AM-864 Compressor w/Output Control
« Reply #1 on: November 17, 2008, 11:02:19 PM »
Sorry for the image snafu, gang.  Here is the link:
http://i247.photobucket.com/albums/gg122/darthneighbor/AM-864.jpg?t=1226980172
I guess another Q would be how to embed images into these posts.  I tried my usual html, but no go.
edanderson
« Reply #2 on: November 18, 2008, 12:12:43 AM »
i've been able to see the attached image in the post since you posted originally earlier today.  some other posts apparently have images that i can't see, however.
what you're proposing seems like it will work in theory.  i'd be inclined to use a two deck rotary switch, but we know a pot "works" up front in the same way, so i bet a pot will work here also, at least as a proof of concept.
because there is generally way too much gain in these units, i'd say go ahead and use a higher ratio stepdown output transformer also, if you have that option.
ed
NewYorkDave
« Reply #3 on: November 19, 2008, 09:40:16 PM »
It will work. I used a similar arrangement in the tube comp I designed--a dual-ganged level control between vari-mu stage and output amp. It should be mentioned that this is not a mod you can slap into any ol' tube compressor. It won't work in most "typical" vari-mu designs due to the take-off point for the sidechain. In those cases, the traditional 600-ohm attenuator after the output transformer is the way to go.
I agree with Ed... a stepped output control is best, but a regular dual audio-taper pot will probably work well enough unless the two sides track really badly.
schmidlin
« Reply #4 on: November 20, 2008, 02:00:54 AM »
Thanks for the input.  I assumed since the compression action took place prior to the mod, it seemed on track.
Do you all recommend the stepped control b/c dual pots are usually not matched quite right?
Last post April 08, 2006, 07:18:56 AM
by gary o
Last post August 14, 2006, 11:38:32 AM
by enthalpystudios
Last post October 01, 2006, 01:11:45 AM
by pimp
Last post March 16, 2007, 04:00:06 PM
by cannikin
