Thanks to all for liking...
Yes, the panels are engraved by Schaeffer/Frontpanelexpress.
The Pico was the first device I built.
When you look at the pic you'll see that the R and S in Threshold and the A in Makeup are not "printed" well because I used a 0.4mm engraving tool at a 2mm letter height. This can lead to problems on a painted frontpanel. I used only the 0.2mm engraving tool later which is a little bit limitating when trying to find a good layout. I like the way I mixed 0.2 and 0.4 mm engraving tools on the Pico here.
