basementmedia
Active member
- Joined
- Nov 16, 2008
- Messages
- 25
with the installation of the Turbo Board i've finally finished my GSSL-Gear but i'm not sure if the thing is working correct so i want to calibrate it.
Does the following procedure therefore make sense:
1. I generate a 0 db Signal with the signal generator of wavelab and inject this into the Inputs of the GSSL.
2. i connect the outputs of the gssl to the inputs of my Audio-Interface.
3. i switch the compressor off and readjust the input level of the audio-interface until i get 0 db input level (so i can be sure that the Signal is passing thru without gain reduction related to the input level).
4. i turn the treshold to 12 o'clock position (0db) and swicth the compressor on --> Now there should be no gain reduction. when i slighly turn the Treshold counterclockwise the compression should start.
If the compression starts already at 12 o clock or later (e.g. one o'clock), i have to put an Resistor at the + leg of the Threshold Poti. If the compressor compresses to late (e.g. in 11 o clock position) i have to put an resistor at the - leg of the Threshold Poti.
So far correct?
And then i would repeat the procedure at fully Counterclockwise position (with -20db Signal?).
Also correct?
But i have read also about guys who changed other resistors too (the 47k's at Sidechain input with 120 k's, and so on), so can anybody tell me the whole way to get the thing doing what it should do?
Cause i have also the suggestion that the Ratio is not working correct...
Every help is appreciated.
Jakob, are you here ;-)?
Greetz
Daniel
So far correct?
Also correct?
Greetz
Daniel
