I am looking for some female mating pins that will take pins from 2520 op amps, I know that this has been covered before, but i have an added requirement.
up until now i have been using the pins that Jeff sells at Classic API and then enlarging the holes on vero board so that they will fit, but this is a somewhat in elegant approch and i am now looking for sockets that will fit straight into the 1mm holes. the item that i have found is https://www.mill-max.com/products/rec/1313 and the only available source for these is digikey http://www.digikey.co.uk/product-search/en?pv30=1&k=1313-0-15&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
could someone have a quick look over them to double check that these will accept 2520 pins, below is the dimensions of the pins that Jeff uses in his op amp kits. much appreciated.
Mill-Max #3103200210000080 @ $0.20 each
Contact Finish: 20μ” Gold Over Nickel
Flange Diameter: 0.070" (1.77mm)
Plated Thru Hole Diameter: 0.043" (1.09mm)
Pin Diameter: 0.040" (1.02mm)
Length: 0.402" (10.21mm)
Arthur
