tardishead
Hi folks
in RDHB4 in the expander section there is a circuit using 7Q7 tubes which has a reasonably fast attack and release time and looks relatively easy to build. Quite simple and elegant. Is this worth building for audio studio use or can someone see any inherent problems?
It says it was included in an amp that at 30 watts and 20db expension had over 5% THD. Thats alot hey or is that more to do with the nature of the power amp????
I was going to add a push pull 6v6 output section and an input transformer.
There is also an expander with 6l7s
