plumsolly
wondering if anyone knows the answer to a couple questions about the neumann lollipop capsules:
the connector only has 2 seperate contacts? one pin on the inside and the outside/housing which is connected to ground/mic body? so with an m7, for instance, only the backplate and front diaphragm are connected? the u47p, therefore, is cardiod only with an m7 capsule?
thanks, sorry for so many questions, Ben
