Yes, of course, encoder. So it can be that there is a connection between the encoder and the select buttons? Would this result in dysfunctionality?
Quote from: Janzoulou on January 04, 2016, 10:28:38 AMYes, of course, encoder. So it can be that there is a connection between the encoder and the select buttons? Would this result in dysfunctionality?i really doubt. Encoder just adds up/down info to the Pic
Now it went even worse. It fires up, goes to saved state (CUT + INPUT 1) and from there nothing is happening anymore.If the EPROM goes to saved state, does that mean that it is working or can it be that it is gone?Thanx in advance for helping out... I´m in real trouble as this is the heart of the studio...
If you haven't seen it already, but there's a small amount of additional troubleshooting info which Igor provided to me when I was trying to fault find my CRM. http://groupdiy.com/index.php?topic=30914.msg520226#msg520226This was the info which enabled Igor to tell the EPROM was dead. Perhaps it'll help you...
@Janzoulou. has your CRM ever worked correctly? Sorry I missed that point?
Here is the pic. I still can't believe it's broken PIC. As someone mentioned before, dead PIC will cause totally wrong behaviour or no response at all.
Started by jhaible « 1 2 » The Lab
Started by Igor « 1 2 3 4 5 » Preamplifiers
Started by Igor « 1 2 ... 6 7 » Filters/Equalizers
Started by niconeemis Black Market
