Ptownkid
Cutting an anti-static mat...
« on: December 19, 2008, 04:09:45 PM »
I have a run of the mill anti static mat, but it's slightly too large for my desk. Can these be cut? Are they simply made with a conductive layer in the middle?
ColinS
Re: Cutting an anti-static mat...
« Reply #1 on: December 19, 2008, 04:27:36 PM »
They're usually made of fairly inflexible conductive plastic (same kinda stuff you get in some types of shielded cable, only thicker), so as long as you don't cut the bit off with the earthing stud on, it should be fine.... (I hope, otherwise my name will be more mud than I'm used to)
Blue LEDs make the world go round
walter
« Reply #2 on: December 23, 2008, 11:58:45 PM »
We use this stuff at work, comes on a roll, cut it to size with a razor. I don't know how conductive it is, checked with an ohmmeter it's highly resistive. I like to work on powered gear right on it. But it is connected to ground, you can even clip an aligator lead to the edge if there's no button. They keep throwing out rolls of the used bits, if anyone's interested, I grabbed a few.
Blown like a fuse
Last post September 06, 2006, 09:35:18 AM
by JAYJAYBEE
Last post April 25, 2007, 12:58:19 PM
by
Last post November 13, 2009, 10:38:13 AM
by rafafredd
Last post January 16, 2013, 09:48:45 PM
by pucho812
