microx
I am confused. The measured noise level of equipment or components seems to lack a standard. EG: an audio power amp is said to have a noise level of -85dB, compared to what?. I have seen such things as "below rated output" fair enough ,you inject a tone at a level which resuts in say 50W into an 8R load then remove the signal and measure the noise. The two will have a voltage ratio which can be expressed in dB's. So far so good but the the other day I am searching for mic capsules and I find an electret that has an SPL of 130dB and a noise level of -66dB. Is that purely it's self noise including the FET or was it measured by applying an audio signal at a specific frequency etc at a level which produced a certain output and then removing the signal and measuring the noise.
IS there a standard and if there is has anyone told the manufacturer.
Steve
Steve
