rascalseven
I may have a knack for stating the obvious, but good grounding is critical for optimum noise performance (never mind any safety issues caused by bad grounding).
A few days ago I finished (I had thought) two sets of S800 dual-channel eq's using Purusha's cases. I connected the audio and psu grounds at the AC inlet, but neglected to connect to any part of the chassis. So they worked fine, but I was getting some hum while mixing yesterday, and I'd get an occasional 'snap' in the signal when I'd touch the front panels. Then it hit me that there was no chassis ground connection!
I'm a religious grounder (just ask my kids ), but for whatever reason I totally neglected this part of the build this time around. So last night I took them apart, used a dremel with sanding wheel to grind away some of the powder coat around enough holes in the panels to allow them to all conduct together when the chassis were reassembled, put them back together and ran a ground wire from the AC inlet ground pin to a single spot on the chassis.
I resumed mixing with them today, and nothing but sweet silence (and nice eq with signal applied, of course).
Like I say, grounding is pretty obvious stuff, but I just missed it on this project for whatever reason, and thought it might be useful to send out a little reminder.
As you were.
JC
As you were.
JC
