Svart
I noticed the other day that one of my mk012's output was lower than the other one. I swapped the capsule and it moved with the capsule.
I removed the outer screen so that I could see the diaphragm through the brass plate and noticed that one corner of the capsule is wrinkled like it has come loose, like the head of a drum that has a couple lugs too loose on one side.
Anyone else seen this problem before? I was using this mic a couple weeks ago and it was fine. I haven't moved them from their stands and the humidity/temperature in the studio has been constant.
