Just got a used/bad u87 capsule.
4 wire.
plastic, backplate spacer about .022 inch thick I measured .021 to .023 inches depending on where I was on the ring?, about 33.88mm OD about 27mm ID it is had to measure this piece
my micrometer is in inches thats why the mixed measurements
Backplates measure 33.88mm in Dia. and ABOUT 4.19mm thick I have not taken the ring and skin off yet.
Question what is the best way to measure the bore holes and thur holes?
before I send it of to get it reskinned I want to measure what I can.
Tim how does this compare to your k67?
4 wire.
