thanks to the both of you for your input. I know that dc offset can be a bad thing, but being that these two IC's will be living together on one board, with no switching or disconnecting between them, I thought a decoupling cap might be unnecessary. Both the 1512 and 1646 demo board schematics show no input or output caps, as well as the 1512 demo board only has the empty footprints for dc servo on the gain control, and not the output of the opamp. So that's what lead me to ask if there was a reason for decoupling the two, or can the 1646 get along fine with the possible 250mV offset (if even that). I WILL be decoupling the output of the 1646 for good measure, even though my ADA I/O has decoupling caps...
so I guess I'll just try it out with a jumper in the place of a decoupling cap and if that doesn't work, I'll just throw a cap in.
thanks again! GREAT forum!
