Talkback Combiner PCB'S
« on: January 24, 2009, 03:33:01 PM »
Hi to all, here's the schematics, comp placement, etc for
Talkback combiner.
http://i251.photobucket.com/albums/gg291/diy33609/tb_comb_pcb.gif
http://i251.photobucket.com/albums/gg291/diy33609/tb_comb_sch.gif
http://i251.photobucket.com/albums/gg291/diy33609/tb_comb_pcb-1.jpg
http://i251.photobucket.com/albums/gg291/diy33609/tb_comb_assembled.jpg
Ordering:
http://www.groupdiy.com/index.php?topic=29771.0
BOM:
RESISTORS
1   1r       5% 7.5MM PITCH      R39
2   3R3      5% 7.5MM PITCH      R35, R40
5   75R       5% 7.5MM PITCH      R18, R21, R31, R34, R1
1   150      5% 7.5MM PITCH      R6
3   1k2      5% 7.5MM PITCH      R36, R37, R38
3   4K7      5% 7.5MM PITCH      R2, R5, R8
2   4k7      5% 7.5MM PITCH      R9, R22
2   5k6      5% 7.5MM PITCH      R17, R30
2   10k      5% 7.5MM PITCH      R12, R25
10  20k      5% 7.5MM PITCH      R10, R11, R15, R16, R19, R23, R24, R28, R29, R32
1   *68K     5% 7.5MM PITCH      R4
CAPS
NON-POLAR
1   0.1u     63V         7.5MM POLY               C1
4   224 (47...220n)    5MM CERAMIC 50V      C19, C20, C21, C22
7   15P (10..22p)      5MM COG 50V             C6, C10, C11, C12, C16, C17, C4
'LYTHIC
3   10U       CPOL-EUE2.5-7      C7, C13, C3
3   47U       CPOL-EUE2.5-7      C2, C8, C14
8   100k     5% 7.5MM PITCH      R3, R7, R13, R14, R20, R26, R27, R33
4   100m 35V     CPOL-EUE3.5-8   C18, C23, C9, C15
1   100U 16V     CPOL-EUE2.5-7   C5
MISC
1   ONE CHEAP MICROPHONE (WHICH WORKS WITH SOUNDBLASTER)
1   10k        TRIMPOT 20T B90P    TB_GAIN
1   LED3MM     LED3MM              LED1
4   JACK 6.3MM PCB                 INL, INR, OUTL, OUTR
1   TL074P     QUAD OPAMP          IC2
1   TL071      SINGLE OPAMP        IC1
2   nsl-32sr3  OPTOCOUPLER         OK1, OK2 (HIGH Roff 10-50MS Toff OPTOCOUPLER)
3              MOLEX-02            12V, TB_MIC, TB_ON
1              MOLEX-03            +/-15V
1              DC/DC CONVERTER     12->+/-15V like farnell p/n 1671264
« Last Edit: July 08, 2009, 06:21:28 AM by clintrubber »
http://www.ij-audio.com
(new site hopefully will be up in July)
plumsolly
Re: TALKBACK COMBINER PCB'S
« Reply #1 on: April 19, 2009, 10:50:59 PM »
Hi Igor - sorry if the answer to this is obvious. this can run on either 12v or +/-15v right? we don't need both? thanks, Ben
kibadachi
« Reply #2 on: July 08, 2009, 05:10:28 AM »
Hi ,
Where do i connect the TB_ON from the talkback combiner PCB to in the audio box? (the black and brown wire in the photo)
clintrubber
Re: Talkback Combiner PCB'S
« Reply #3 on: July 08, 2009, 06:23:22 AM »
Thread title adapted to the more common & desirable usage of uppercase & lowercase on these forum pages.
Regards,
  Peter
crisotop
« Reply #4 on: July 17, 2009, 03:06:20 PM »
R16 & 23 are labelled 3k3 on the pcb, but should be 20k according to the schematics and bom, am I correct?
Christoph
« Reply #5 on: July 18, 2009, 04:25:04 PM »
R16 and R23 are 20k, right.
crisotop
« Reply #6 on: July 19, 2009, 05:09:28 AM »
crisotop
« Reply #7 on: July 28, 2009, 01:35:29 PM »
Hi , Where do i connect the TB_ON from the talkback combiner PCB to in the audio box? (the black and brown wire in the photo)
Good question, from looking at the schematic I suspect the two 100R resistors on the audio board - Igor could you confirm this? also are there two spare leads in the control sub-d cable that are reserved for the electret mic in the remote control?
thanks
christoph
« Reply #8 on: August 09, 2009, 02:48:30 PM »
Christoph, it goes this way:
wnen on terminals tb_on there's 5v, talkback signal is combined with audio.
To connect the tb combiner to CRM, use tb_on terminal on CRM audio pcb. They have same pinout.
100r resistors usen in case something shorted from outside, just to save expensive A6833 relay driver.
Sylvain D.
« Reply #9 on: August 10, 2009, 11:22:23 AM »
Hi Igor,
I can't match up the spacing dimensions for the pins on the 1/4" trs jacks with Neutrik or Switchcraft. Can you please tell me what model connectors you used on the tc?
Sylvain
yosh
« Reply #10 on: August 10, 2009, 02:52:39 PM »
This is what I used for the phone jacks:
Neutrik part no. NMJ6HFD2
Mouser part no. 550-20301
Parts fit pcb fine. I haven't tested it yet, but I think the pinout is right.
-Josh
My Portland, Oregon based recording studio: www.themaproomstudio.com
Sylvain D.
« Reply #11 on: August 10, 2009, 03:58:24 PM »
Thanks Yosh!
I'll hunt those down.
S. :)
plumsolly
« Reply #12 on: September 27, 2009, 02:51:37 AM »
Hello - I'm starting to source parts and I wasn't sure what this meant.
CPOL-EUE2.5-7
Thanks, Ben
rob_gould
« Reply #13 on: September 27, 2009, 04:24:21 AM »
It means polarized capacitor (ie electrolytic) and then I believe the numbers on the end are pitch of the legs and diameter of the body of the component.
Something like this would work I believe :
http://uk.farnell.com/panasonic/eca1vad100x/capacitor-10uf-35v/dp/8766940
Studio furniture, modular synth cases and more...
www.gouldcaseworks.nl
plumsolly
« Reply #14 on: September 27, 2009, 07:22:15 PM »
Thanks again Rob! - Best, Ben
plumsolly
« Reply #15 on: October 11, 2009, 06:43:30 PM »
I am still getting together parts, and I noticed C15 and C9 are listed as 100uF on the schematic and layout, but 100mF on the BOM. Also is 100mF (100milifards = 100,000uF)  correct?
Thanks, Ben
« Reply #16 on: October 11, 2009, 07:50:52 PM »
100uF is correct value.
plumsolly
« Reply #17 on: October 11, 2009, 09:48:16 PM »
Thanks, Igor - So C18 and C23 are 100uf as well?
Thanks again, Ben
« Reply #18 on: October 12, 2009, 04:28:31 AM »
Use logic :)
plumsolly
« Reply #19 on: October 12, 2009, 04:05:40 PM »
Use logic :)
I'm assuming that C18, C23, C9, and C15 are all 100U - But I can't figure out why, if you meant 100U when you wrote 100m, you would list some values as 100m and some as 100U. Or maybe I have it all muddled, but there are discrepancies between the BOM and the schematic that make it even more confusing. I really appreciate the excellent kits and your contribution to the forum, and I am trying not to ask for step by step instructions.
Thanks again and Best, Ben
« Last Edit: October 12, 2009, 04:09:50 PM by plumsolly »
Last post September 13, 2017, 11:40:36 AM
by groselicain
Last post April 08, 2005, 05:53:09 PM
by Kev
Last post February 02, 2011, 03:43:47 AM
by abbey road d enfer
Last post May 07, 2020, 11:31:05 AM
by Govinda Doyle
